• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    DSM_dude
    Re: DELETE NAVIGATION CUBE FROM DRAWINGS
    08-25-2011 06:05 AM in reply to: kewaunee2011
    navvcube > off
    Cad Blog:
    www.geaux-cad.blogspot.com
    Please use plain text.
    Member
    kewaunee2011
    08-25-2011 06:59 AM in reply to: DSM_dude
    SOLVED THE ISSUE:
    FILE: OPEN: (down at the bottom where is says "files of type") ".dwt"
    Then went to my standart template that i use for new drawings "ACAD.dwt"
    Once inside template drawing: TOOLS: OPTIONS (@ bottom): 3D MODELING TAB
    Look at bottom left hand corner for: "DISPLAY VIEWCUBE OR USC ICON"
    check the first box under 2D model space that says "Display ViewCube"
    then check the first box under 3D model space that says "Display ViewCube"
    Click "APPLY" & "OK"
    Your viewcube should be gone, now "SAVE"
    Make sure to check an exsisting drawing for it to be gone and if you didnt close out of a drawing you were working on before you started these steps the NaviCube will probably still be visible.
    I cammand line type:  NAVVCUBE: <OFF>         "SAVE" your current drawing and you should be set.
    Make sure you change back your "files of type" back to ".DWG" so you will ba able to access your ACAD files and thats it.
    4min tops to do and no more frustration.
    Hope it helps
