• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    DEFAULT SCALE LIST
    1121 Views, 1 Replies
    05-02-2012 11:03 AM
    Hi all,
     Is there a way to modify the DEFAULT SCALE LIST to show a metric scale list in an imperial template? I mean, I start a drawing using the imperiial template, but i wan to use the standard metric scales on paper spcae. on previous versions the scale list shown both imperial & metric. Now it depends of what the template is using.
     can you help me?
    thanks in advance.
    Please use plain text.
    Valued Mentor
    MarySeufert
    Re: DEFAULT SCALE LIST
    05-02-2012 11:24 AM in reply to: johny_dominguez
    Use SCALELISTEDIT, select Reset. the Scale List - Reset dialog box should pop up select the list of scales you want loaded. You can choose Metric only, Imperial only, or both. Do a saveas of the OOTB template file with these changes made in it and set it as your default drawing template.
    ~ Mary
    ___________________________________________________________________
    Normal people believe that if it ain't broke, don't fix it.
    Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
