• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    SteveAdams8888
    Accepted Solution
    Custom Block Tool Palette: Scaling of the Block...
    302 Views, 2 Replies
    03-30-2011 05:39 PM
    I made a custom block palette using DesignCenter, but when I insert the block from the palette, it comes in scaled at 1:1, instead of my annotation scale. There is a scale property in the tool on the pallette, but it is set to "1", and I want it to come in at the dwg scale (annotation scale?).
    I'm thinking: maybe I need to make the block "annotative", but when I click on the inserted block and display the Properties, there is not a Property for "Annotative" for me to change.
    Can you help me get my blocks to come in at the Annotative scale, or the "ltscale"?
    Steve (using C3D 2010)
    Steve
    C3d 2010 (no SP)
    Win7
    Please use plain text.
    Distinguished Mentor
    Re: Custom Block Tool Palette: Scaling of the Block...
    04-21-2011 02:08 PM in reply to: SteveAdams8888
    I don't know if making the block annotative will solve your problem, but if you want to try it, it is done in the block editor (BEDIT, not REFEDIT).
    Once in the block editor, with nothing selected, use the Properties palette to change the Annotative property in the Block section.
    SteveAdams8888
    05-14-2011 08:32 PM in reply to: dmfrazier
    Thanks dm,
    That fixed me right up.
    I appreciate it,
    Steve
    Steve
    C3d 2010 (no SP)
    Win7
