• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Copying Viewports
    1066 Views, 6 Replies
    06-02-2011 07:30 AM
    In some drawings the viewports automatically display viewport objects when I copy them and some they do not. There must be a systems variable and I searched through the systems variable tool in the Express tools and couldn't find it. Does anyone know how to get consistent results when copying viewports.
    Thanks!
    Lisa
    Please use plain text.
    pendean
    Re: Copying Viewports
    06-02-2011 07:33 AM in reply to: lbernacchi
    My experience has always been they stay on if you remain in the same DWG file, you have to turn them on if you go to other DWG files.
    Is that not the same for you?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    06-02-2011 07:41 AM in reply to: lbernacchi
    Nope, that is why I'm asking. In previous releases they were always off. When we upgraded to 2010 I was so excited that they are on when you copy. I have one drawing where the viewports don't stay on. I don't want to rebuild this drawing just because of this issue.
    Bob_Zurunkle
    06-02-2011 09:34 AM in reply to: lbernacchi
    If you mean copying them from one layot tab to another in the same file, they should retain their layer settings in newer versions of AutoCAD. If you're trying to copy from one file to another it won't work. In older versions, you can make the viewport a block and then copy it to another tab in the same file, and then explode it -- and it should retain its layer settings that way.
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    *Pro
    nestly
    06-02-2011 08:38 PM in reply to: lbernacchi
    REGENAUTO > ON
    Valued Contributor
    06-03-2011 04:41 AM in reply to: lbernacchi
    THANK YOU!!! I knew it was a setting.
    Active Member
    NeilJ55
    02-28-2012 08:45 AM in reply to: lbernacchi
    thank you for the information about the Regenauto command
