• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Copy with base point problems
    280 Views, 5 Replies
    07-09-2012 02:06 PM
    When I use the copy with base point command in paper space and try to paste it into paper space of another drawing it seems to come in on a different axis or something. I can see the view ports as they are supposed to be however the text just shows as a line. It would be as if I were to put text in model space on top view and see it just fine then go to a front view and see just a line. Does this make sense? Has anyone found a solution to this problem?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Copy with base point problems
    07-09-2012 02:37 PM in reply to: ryan0416
    What are UCS and PLAN set to in both drawings?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    07-09-2012 02:43 PM in reply to: pendean
    UCS is set to World in both drawings. Not sure what the Plan is where would I look for that?
    Thanks for you reply!
    *Expert Elite*
    pendean
    07-10-2012 05:02 AM in reply to: ryan0416
    PLAN could be set to WORLD as well in both files, to match your UCS.
    07-10-2012 08:47 AM in reply to: pendean
    The "Plan" command is only valid in model space. I am trying to get paper space text and dimensions to copy over to another drawing. Would the plan setting in model space some how effect my paper space? Both plan and UCS are set to world currently.
    07-10-2012 08:49 AM in reply to: ryan0416
    Somehow everything is working fine today and I have changed nothing. Must have been a glitch in autocad. Have you run accross this issue before?
