AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Copy to Clipboard failed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I select an object,
then press Ctrl+C
I get this error message
"Copy to clipboard failed"
Help please.
Re: Copy to Clipboard failed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
List and see what it is, if it is AEC/proxy , no can do.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A coworker of mine just had the same problem. What she was trying to copy to the clipboard was a block definition. I went into the block to look for AEC objects, and none were found.
I ran the AUDIT and PURGE commands, and everything was clear
It turns out the block (a civil plan) had other blocks nested within. I went into the main block through the block editor, exploded the nested blocks, and saved the main block
I ran the AUDIT and PURGE commands again, and this time it found a whole whack of errors.
Once they were clear, I was able to copy the objects to the clipboard
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What is AEC/Proxy? Can you expound?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Example of Civil AEC objects:
With plain autocad polylines are polylines, but in Civil, polylines can be convert to AEC Contours, they hold locations, elevations so when you make a cross section trough them, the program generates hills and valleys and calculates cut / fill of how much dirt, etc......
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've ran into this problem when trying to copy annotative objects.
www.geaux-cad.blogspot.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just got this bug today for the very fisrt time (in AutoCAD 2012).
I tried to Copy/Paste a BlockReference (for a title block filled with attributes). So I went in Block Editor to check if I could Copy all the entities that way and it worked. So in my case the problem was not the BlockDefenition so I closed the Block Editor.Then I did a "ATTSYNC" command to reset the faulty BlockReference. And after that the Copy/Paste did not failed! ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ah Hah... Not the only one. So Bizare.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Anyone figured out this problem?
I've never been able to figure it out.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just happend to me - a rare problem. I've tried purging and recovering the drawing without success. Then saved to R12 DXF, closed it, opend the DXF, saved to current 2013 DWG and the problem went. After correcting some settings and defining new layouts the model id fine.
