AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Coordinate System warning
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just installed ACAD 2012 (via infrastructure design suite) on a new computer. I have been getting the following error when opening existing drawings. I can't find any documentation about this and what it means. Has anyone seen this? Is there a way to change the version of my coordinate system?
Mike
"Warning: Drawing S:\... was created with a version of coordinate system 'XY-M' that is different from the version installed on your system. Coordinate conversion operations may generate incorrect results."
Re: Coordinate System warning
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Mike,
In which program and version were the drawings created?
Which coordinate system was used?
Cheers,
Luciane
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just had this problem.
open the drawing and paste this code at the command prompt:
(setq cscode "")
(ade_projsetwscode cscode)
Save the file and exit autocad.
Reload autocad and reassign the coordinate system.
I hope this helps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This worked great for us. However we've ran into this error message again, yet it only happens to one of our users when they bring in certain blocks. When our other users bring in those same block, there is not problem. I don't see how I to fix it if there is only one user having this issue. I went into those same blocks and ran the suggested command but it still doesn't work for that one user.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for posting this command! Only happens on one machine with one user. He only has a couple more projects to wrap up with this software. All else is C3D. This workaround is great! I suspect the bigger issue is files assigned coordinate systems on XP 32 bit machines, then opened on Win 7 64-bit machines... Not sure though and won't be getting into that I sure hope.
ChetHugo8368 wrote:I just had this problem.
(setq cscode "")
I hope this helps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well we have mulitple users and this problem was affecting everyone so we had to remove and reset all the coordinate systems in a bunch of blocks. After we done that everyone's worked perfectly, until now. Now there is only one user that this is affecting. If we do the the same remove and reset the coordinates to the blocks that are causing her problems it doesn't correct the problem. The error continues to pop up. We're all using windows 7 and 64bit machines.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is it possible that she is using different files from the other users?
Cheers,
Luciane
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I double checked and she's using the same templates & blocks as all the other people that don't have any issues. I have not tried reinstalling autocad yet but wondering if that may fix the issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, you can try that and then install the latest updates for the product.
Cheers,
Luciane
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We are getting a similiar warning when using a user defined coordinate system. The fix provided earlier doesnt work for us. But I am wondering if it should. Is this warning in our case just letting us know that this is a user defined coordinate system. Any one else having the similiar issue with user defined coordinate systems
