• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    karenhamilton
    Converting dtext to mtext in AutoCAD 2010 Lt
    185 Views, 5 Replies
    01-04-2012 08:42 AM
    Since the LT version doesn't have Express Tools, is there a way to convert dtext to mtext?   Thanks.
    Please use plain text.
    Bob_Zurunkle
    Re: Converting dtext to mtext in AutoCAD 2010 Lt
    01-04-2012 08:49 AM in reply to: karenhamilton
    The only thing I can think of is to start an Mtext object and then copy all of your Dtext objects into it...
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    pendean
    01-04-2012 02:17 PM in reply to: karenhamilton
    None unless you want to spend the time copying and pasting between the editors: open two sessions of AutoCAD, MTEXT in the first session (so you can SAVE), and the same file in the second session (it does not need to save). That way you don't have to stop and restart each editor.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    01-05-2012 07:35 AM in reply to: pendean
    you can also copy dtext to word document, and the copy it from word to mtext window.
    Patchy
    01-05-2012 07:43 AM in reply to: karenhamilton
    If I have to do this for many drawings I would get  30 days trial.
    Too painful to copy paste
    Active Member
    karenhamilton
    01-05-2012 08:02 AM in reply to: karenhamilton
    That IS a solution but it almost seems easier to just retype my text.  I would only need to convert short phrases anyway.
    Thanks.
