• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    aguritzky
    Converting Blended Surfaces To Solids?
    2565 Views, 14 Replies
    02-16-2011 09:07 PM
    I have created an object using multiple surfaces some are revolved some are blended and would like to convert them to a solid object. I have tried surfsculp, surface offset, and thicken but none of them work. The surfaces do not create a watertight object but I do not understand why not, everything has been blended. When I try to offset it fails and when I use thicken it tells me that the object intersects itself. I do not know what to do can anyone help?
    Please use plain text.
    Valued Mentor
    stevenelliott3894
    Re: Converting Blended Surfaces To Solids?
    02-17-2011 08:11 AM in reply to: aguritzky
    Unfortunately, AutoCAD cannot convert a surface to a solid like you wish. If you could manage to convert it to a closed mesh, then AutoCAD *might* be able to make it into a solid with CONVTOSOLID. This is an unfortunate situation that has been around since they started using solids technology (release 13), and they haven't seen fit to address this issue. Sorry.
    Steven Elliott
    When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
    aguritzky
    02-17-2011 08:48 AM in reply to: aguritzky
    Thank you for your response. I have tried to convert it into a mesh, when I do it becomes very ugly and rough and creates alot of holes even after using smooth mesh. I tried to patch the holes with the proper command (I cannot remember the name off the top of my head), but it actually just makes it worse.
    I also have Inventor I am just not as familiar with it. Is there anyway I can import the drawing to Inventor and convert it into a solid? Or will I have the same issues?
    Valued Mentor
    stevenelliott3894
    02-17-2011 08:52 AM in reply to: aguritzky
    Sorry, I know very little about Inventor. There are many Inventor users here, so maybe one will chime in. Other than that, I would suggest downloading a demo of Inventor and trying things out for yourself, to determine if it can meet your needs.
    Steven Elliott
    02-20-2011 06:26 PM in reply to: stevenelliott3894
    stevenelliott3894 wrote:
    ... I would suggest downloading a demo of Inventor and trying things out for yourself....
    uhhmm didn't the OP indicate already having Inventor?
    Of course a question of this type of any complexity cannot possible be answered without a file.
    Valued Mentor
    stevenelliott3894
    02-21-2011 05:14 AM in reply to: JDMather
    Uh... yes... yes, he did. I referred quickly back to his first post when I wrote that, but he didn't say it until his second post. Way to jump in there with unimportant criticism!
    Steven Elliott
    02-21-2011 12:10 PM in reply to: stevenelliott3894
    Unzip attached Part1.sat file.
    Issue the acisin command.
    http://au.autodesk.com/?nd=class&session_id=3056
    Valued Mentor
    stevenelliott3894
    02-21-2011 12:18 PM in reply to: JDMather
    Is this supposed to convey a message to me?  :robotindifferent:
    Steven Elliott
    aguritzky
    02-21-2011 02:09 PM in reply to: JDMather
    Lol, I am staying out of this one. But thanks to everyone for the help it is appreciated.
    aguritzky
    02-21-2011 05:26 PM in reply to: JDMather
    The part looks great in Inventor but I do not know how to get the file into AutoCAD?
