• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Accepted Solution
    Controlling Vertices in Qleader
    53 Views, 3 Replies
    03-07-2012 12:28 PM
    How do I make the Qleader retain 3 vertices when I stretch the vertices?  It's fine if I do not enter any text with the command and then create separate MText, but I'd like to use the command as it's written.  However, if I start stretching the endpoints around on the screen, I will end up with extra vertices in the line, and I cannot get rid of them.
    Thanks!
    Please use plain text.
    Valued Mentor
    gjrcmb
    Re: Controlling Vertices in Qleader
    03-07-2012 01:09 PM in reply to: mamie.anding
    Yeah see what you mean.  How about using MultiLeader with MText?  Does not seem to have the same issue.
    Gavin Rouleau, PE
    C3D 2012 SP1, Win XP Home
    Active Contributor
    03-07-2012 01:41 PM in reply to: gjrcmb
    Ahhh, once I found it, it's exactly what I need.  Thanks!
    Valued Mentor
    gjrcmb
    03-07-2012 01:59 PM in reply to: mamie.anding
    Nice.  It seems like MLeader is more versatile than QLeader anyway.  :smileywink:
    Gavin Rouleau, PE
