• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    INEXIT
    Re: Configure Proxy for Autodesk Account in AutoCAD 2012
    07-26-2011 04:55 PM in reply to: mjlaca
    Finally fixed it!  (with a little help from the proxy vendors)
    Autocad is having trouble with the authentication method (user authentication), so an exception needed to be made on the proxy server to allow authentication via computer IP address instead.
    I hope this information is helpful to someone  :smileyhappy:
    Please use plain text.
    Product Support
    07-27-2011 01:33 AM in reply to: mjlaca
    Sorry for the confusion. if you are clicking on "X" it is connecting to Exchange using adexchange.exe
    When you click on Signin->Signin within Autocad, acad.exe will try to login to the website(which needs the 3 domains mentioned earlier)
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    joe
    Active Member
    08-19-2011 06:31 AM in reply to: INEXIT
    Yes, It appears AutoCAD does NOT send any authentication.
    If your proxy server requires Authentication then no internet appears possible inside AutoCAD.
    The only option you have is to stop your proxy server from asking for a username. Usually proxy servers ask for a user name to log which users are visiting which sites. Many proxy servers allow you to turn this off.
    To fix this for Microsoft ISA 2004  or ISA 2006 proxies, the outgoing HTTP rules need to be set to 'ALL USERS' and not 'ALL AUTHENTICATED USERS'. In ISA 'All Authenticated Users' will force the application to supply a username and password.
    I think this does need Autodesk to issue a fix. The fix should be simple (just push the currently logged in username and password) or have a box inside the autocad options to supply the authentication details,
    09-05-2011 02:58 AM in reply to: joe
    I too have the same issues as Joe;
    Perhaps the fix can be whatever change was applied to the Photoscene Editor application that's part of the Labs' "Project Photofly"
    :smileyhappy:
    New Member
    kumar.ks
    11-17-2011 06:16 AM in reply to: hashim.mundol
    kindly let me know which are the 3 web links?
    Product Support
    11-17-2011 07:57 AM in reply to: kumar.ks
    *.autodesk.com
    *.cloudfront.net
    *.google-analytics.com
    Hashim Mundol
    Active Member
    Juliustiberius
    02-21-2012 05:31 AM in reply to: Juliustiberius
    Finaly fixed as well.
    As somebody mentioned before: AutoCAD does have problems for user authentification at a proxy server.
    I reconfigured our proxy-server to IP-Authentification, which's fine for me. But Autodesk should make some improvements here!
    Best regards from Austria!
    Active Contributor
    11-26-2012 05:10 AM in reply to: Juliustiberius
    Good morning,
    I have the full version of 2012 and 3D walls, doors ect
    that are proxy are just showing up as boxes. How do i fix that?
