• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Changing Units on a existing drawing
    512 Views, 4 Replies
    04-04-2012 08:27 AM
    I have a venue drawing that is in mm and I need to convert it to ft/inch so I can update and get dimensions from it.  Can this be done so when I change the format in drawing units it will update the drawing units?
    Current settings.
    Drawing units
    Length:
    Type - Decimal
    Percisin - 0
    Angle:
    Type - Decimal Degrees
    Precision - 0
    Insertion Scale:
    Unitless
    Please use plain text.
    Patchy
    Re: Changing Units on a existing drawing
    04-04-2012 08:40 AM in reply to: Brett_2000
    Your drawing doesn't know it's mm or inches, km.... it only knows one thing length, so you have to scale the drawing,
    or you can leave it as it is and add dimension factor to it.
    New Member
    04-04-2012 08:51 AM in reply to: Patchy
    How would I do that?
    Patchy
    04-04-2012 09:24 AM in reply to: Brett_2000
    Like this
    DSM_dude
    04-05-2012 01:48 PM in reply to: Patchy
    Create a toolbar with a button. Use the following as the buttom command.
    ^C^C-dwgunits;2;2;4;no;no;no;^C^C(IF (NOT C:smileyfrustrated:CALE-LIST)(LOAD "SCALE-LIST"));SCALELISTREM;SCALELISTIMP;
    the attached lisp is needed!!
    Cad Blog:
    www.geaux-cad.blogspot.com
