AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Changing Mtext width of multiple objects
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a way - or 3rd party app or lisp- to change the width of multiple Mtext objects all at once? I have several drawings where the width of all Mtext objects is 1.25, and I would like to change all of them to 1.
Ideas? Is there some simple way to do this?
Thanks!
Tom
Re: Changing Mtext width of multiple objects
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Select all the mtext objects, open the PROPERTIES palette (ctrl-1), change the width there. You can select all of the mtext objects using the QSELECT in the properties palette or by using a filter. Hope that helps! =)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry.....I mean the character width, not the 'defined width' which is how wide the overall Mtext string is. Is there a way to change the character width, other than going into the dialog box for each individual piece of Mtext?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ahh... is it hard coded into the text? If it is not, you can just change the width factor in the STYLE dialog box.
If it is... well...that sux. I'm not sure how I would change it globally. You might be able to find some lisp routines online that can do it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the width factor is defined in styles then change it there. If it is overriden in Mtext editor then use the attached lisp.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you Toan I'll try that!!
tom
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i tried your stripmtext lisp. nice lisp.
but i want to change text width not whole word width per mtext.
now i have text width of 1.0 .
i want to convert within mtext as 0.8
please suggest
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Use the STYLE command, and change the width factor there. MTEXT will update to reflect the change (note that TEXT objects won't)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Worked perfectly!!!! Great Lisp.
Many Thanks!
