• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Accepted Solution
    Changing Font Style in Nested Blocks
    411 Views, 6 Replies
    03-28-2012 03:23 PM
    Is there a way to change text font style (Text, and Mtext) in nested blocks automatically? I need to do this for multiple nested blocks at once.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Changing Font Style in Nested Blocks
    03-28-2012 03:25 PM in reply to: nothin
    Post a sample dwg file with such a block.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    03-28-2012 03:32 PM in reply to: pendean
    Here's a sample.
    I want to change the text font style from what it is now to Arial.
    *Expert Elite*
    Patchy
    03-29-2012 06:38 AM in reply to: nothin
    I don't see why you can not.
    03-29-2012 10:24 PM in reply to: nothin
    The font style of each nested block can be changed manually by going into each nested block one at a time.
    But you can imagine how long this could take. In the example I attached earlier almost every text string has it's own block. That's twenty or more blocks.
    It would be nice to have a way to automatically change the text in all of the nested blocks at the same time.
    Is there a way to do this?
    *Expert Elite*
    Patchy
    03-29-2012 10:40 PM in reply to: nothin
    Style, change font in Standard to Arial, all changed. Why don't you do that?
    04-03-2012 08:23 AM in reply to: Patchy
    That works great. The only bummer is that if you ever move the nested block into another drawing it will change the font to whatever it is in that drawing.
    But I think this will work for now. Thanks!
