• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    *BigBill
    Change fillet radius on a solid?
    1501 Views, 11 Replies
    05-09-2010 07:28 AM
    Once an edge has been filleted on a solid is it possible to change it?
    Thanks :smileyhappy:
    XP Pro
    Intel Core2 Duo
    p8400 @2.26 GHz
    2.99GB Ram
    GeForce 9800M GTS video card
    __________ Information from ESET NOD32 Antivirus, version of virus signature database 5097 (20100509) __________
    The message was checked by ESET NOD32 Antivirus.
    http://www.eset.com
    Please use plain text.
    *Expert Elite*
    Re: Change fillet radius on a solid?
    05-09-2010 10:32 AM in reply to: *BigBill
    Use the solidedit delete face option to remove the fillet(s) and then put in new fillet.
    You must get all fillets needed to heal the solid for solidedit to work.
    or
    You could download free Inventor Fusion and simply click and drag the fillet to desired size.
    http://labs.autodesk.com
    Here are some older AutoCAD editing tutorials. The interface has changed from Dashboard to Ribbon.
    http://home.pct.edu/~jmather/content/CAD238/AutoCAD_2007_Tutorials.htm
    Some things can be changed from Properties if solidhist is turned on, but I recommend turning solidhist off as I have seen a bug with that functionality. Not sure if they have fixed it in 2011 (bug existed in 2007-2010).
    Inventor Professional 2014 Edu 64-bit
    *BigBill
    05-09-2010 11:05 AM in reply to: *BigBill
    Inventor fusion for autocad?
    XP Pro
    Intel Core2 Duo
    p8400 @2.26 GHz
    2.99GB Ram
    wrote in message news:6388149@discussion.autodesk.com...
    new fillet.
    or
    to desired size.
    2007-2010).
    *Expert Elite*
    05-09-2010 06:17 PM in reply to: *BigBill
    Saves a bunch of rework (trivial simple edits of solids) and saves as dwg file format.
    A must see for anyone in MCAD http://au.autodesk.com/?nd=class&session_id=5457
    Active Contributor
    05-10-2010 05:24 AM in reply to: *BigBill
    Bill,
    Hold your Ctrl key down and select the fillet you want to change.
    Once selected, click the blue grip that pops up. This will give you access to a new "direct manipulation tool" where you can drag the size of your fillet on screen, or you can enter a new value.
    HTH
    Jeff Bartels
    *BigBill
    05-10-2010 06:02 AM in reply to: *BigBill
    Hmmmm I use Control key and pick the radius and no blue anything, but a red
    dot, that is something about a move gizmor or something.....??
    Am I doing it wrong?
    XP Pro
    Intel Core2 Duo
    p8400 @2.26 GHz
    2.99GB Ram
    wrote in message news:6388354@discussion.autodesk.com...
    Bill,
    HTH
    Jeff Bartels
    Active Contributor
    05-10-2010 06:10 AM in reply to: *BigBill
    Set the Solid tab current on your ribbon.
    Check the Subobject panel and be sure it is set for "No Filter".
    If you hold your Ctrl key down and click on the fillet, you should be able to select it.
    Once selected, you should see the grip I mentioned in my previous post.
    If not, press Ctrl+1 to bring up your property changer.
    If your fillet is selected, you can also change the radius there.
    HTH
    Jeff
    *BigBill
    05-10-2010 09:38 AM in reply to: *BigBill
    I tried all that, can only get the red dot as shown :smileysad:
    XP Pro
    Intel Core2 Duo
    p8400 @2.26 GHz
    2.99GB Ram
    wrote in message news:6388395@discussion.autodesk.com...
    to select it.
    HTH
    Jeff
    database 5102 (20100510) __________
    http://www.eset.com
    Active Contributor
    05-10-2010 09:52 AM in reply to: *BigBill
    Bill,
    It appears from the photo that you are able to select the fillet.
    Question - when the fillet is selected, what does your property changer say?
    If you open your property changer (press ctrl+1) when the fillet is selected it should say "Fillet" at the top.
    If this is the case, you can change the radius in the settings below.
    If it shows that you have another type of object selected (possibly says face) then it may in fact not be a fillet.
    That rounded edge could have also been created via an extrusion of the back face. Is this a possibility?
    Did you create the rounded edge using the fillet command?
    Is your solid history turned on? (It appears it may not be based on the image provided)
    Check out the Primitive panel - click the Solid History button and make sure it's turned on.
    If it was in fact turned off, you may not be able to edit the fillet as I have described because the object isn't retaining the data used to create it.
    Ensure the solid history is turned on, create a NEW fillet, and then attempt to edit it.
    This might help you determine what the problem is.
    Good luck!
    Jeff
    *BigBill
    05-10-2010 12:51 PM in reply to: *BigBill
    I do not think the solid history is turned on. Let me try that!
    Thanks!
    XP Pro
    Intel Core2 Duo
    p8400 @2.26 GHz
    2.99GB Ram
    wrote in message news:6388581@discussion.autodesk.com...
    Bill,
    image provided)
    it's turned on.
    it.
    to edit it.
    Good luck!
    Jeff
    database 5103 (20100510) __________
    http://www.eset.com
    __________ Information from ESET NOD32 Antivirus, version of virus signature database 5103 (20100510) __________
    http://www.eset.com
