• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Change Text Case
    816 Views, 9 Replies
    07-20-2011 06:19 AM
    Hi all,
    Where has the global change text case gone?!! It used to be in express tools, if I remember....is there a way to get this command into 2012?
    Thanks in advance.
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Change Text Case
    07-20-2011 06:25 AM in reply to: LukeLans
    Tcase command, if it doesn't run, install Express
    Active Member
    07-20-2011 07:08 AM in reply to: LukeLans
    THANKS! All done.
    Active Member
    AndyKuang
    11-16-2011 06:43 PM in reply to: Patchy
    It doesn't work for me, even I reinstall Express, but txt2mtxt works for my AutoCAD 2012.
    Any other solution?
    *Expert Elite*
    Patchy
    11-16-2011 08:17 PM in reply to: AndyKuang
    Search for TCASE.LSP in your PC, if it can be found, use APPLOAD to load it then use it.
    Active Member
    AndyKuang
    11-16-2011 08:30 PM in reply to: Patchy
    Thanks for you hint.
    I found the TCASE.LSP  in my Computer, how can I use APPLOAD to load it ?
    *Expert Elite*
    Patchy
    11-16-2011 08:47 PM in reply to: AndyKuang
    Type in APPLOAD, click until you find it, click on LOAD
    then type in TCASE
    (Add it to your Startup Suite so it can be available anytime)
    Active Member
    AndyKuang
    11-17-2011 12:34 PM in reply to: Patchy
    Thanks for your help.
    It still not working, here is the message form AutoCAD "tcase ; error: no function definition: ACET-ERROR-INIT".
    I use the APPLOAD and load the " TCASE" and add it to my Startup Suite .
    But when I have a look at the " Loaded applications", the "tcase.lsp" in grey colour.
    Any other solition?
    Thanks again.
    Andy
    *Expert Elite*
    Patchy
    11-17-2011 12:38 PM in reply to: AndyKuang
    Add a path to the Express folder in OPTIONS, restart autocad.
    Active Member
    AndyKuang
    11-17-2011 02:43 PM in reply to: Patchy
    Thanks lot, it works for now.
    Andy
