• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Can't get LWPolylines to join
    200 Views, 10 Replies
    04-11-2012 09:43 AM
    I'm using AutoCAD 2011.  Lately I'm having lots of trouble getting LWPOLYLINES to join, end-to-end.  They were all created with the same UCS on elevation zero.  Some are arcs, and some are straight segments.  I've used PEDIT, MPEDIT, JOIN.  Nothing works.  They are definitely end-to-end.  What am I doing wrong?
    Please use plain text.
    Re: Can't get LWPolylines to join
    04-11-2012 09:46 AM in reply to: kimmyz
    >> Nothing works
    What message do you get from AutoCAD
    Can you  upload a drawing with at least a few of these geometry objects for us to try?
    - alfred -
    Alfred NESWADBA
    04-11-2012 10:25 AM in reply to: alfred.neswadba
    >>What message do you get from AutoCAD?
    It just says "0 polylines joined".
    Unfortunately, I can't email you the drawing because we couldn't wait for a solution.  My workaround was to erase the arcs and redraw, simulating the arcs with regular polylines (not LWPLINES).  It doesn't look nearly as nice, but that's the only thing that seems to work.  I have a LSP routine (CONVPLNES) that converts LWPlines to the old PLINES.  Even that would not join the ARCs to the PLINEs that are most certainly end-to-end.
    Valued Contributor
    04-11-2012 10:41 AM in reply to: kimmyz
    I know you said you checked the UCS, but it would hurt to run the "flatten" command to see if that improves things.
    Unless, you've already tried that.
    °°AutoCAD Rel 1 - 2014°°
    For when the One Great Scorer comes
    To write against your name,
    He marks-not that you won or lost-
    But how you played the game.
    Grantland Rice
    04-11-2012 10:42 AM in reply to: stevecee
    Yes, I did already try that.  Still no luck.  Next time I have this same problem, I'll save a copy of the drawing and upload it to you.  Thanks for trying to help.
    Valued Contributor
    FFlix
    04-11-2012 10:45 AM in reply to: kimmyz
    also:
    1.) is PLINEACCEPT set to 1? if so, when using PEDIT, then chosing [M], are selected non-polylines converted into polylines (as expected)? (there's no immediate feedback on any succesful conversion but any converted entity should remain a polyline if you then escape the PEDIT.)
    2.) provided they are, i.e. all selected entities now are polylines, when then you chose the JOIN option for joining these selected polylines, do you get different results when increasing TOLERANCE at the prompt?
    04-11-2012 10:55 AM in reply to: FFlix
    There's no PLINEACCEPT command or system variable in AutoCAD 11.  The arcs and LWPlines were created end-to-end with OSNAPS, so tolerance shouldn't be an issue.  I was very careful to make sure they were end-to-end.
    Valued Contributor
    FFlix
    04-11-2012 12:56 PM in reply to: kimmyz
    my apologies, it's PEDITACCEPT (as opposed to plineaccept).
    on the risk of sounding pedantic, have you 1.) confirmed that the selected entities are indeed converted into polylines (either via systemvariable or prompt)? and if so, have you 2.) tried increasing the tolerance?
    to explain: OSNAP may work perfectly accurate, however all point properties need to be stored as x,y and z-coordinate etc in the .dwg database until some time later they may be used by the JOIN routine. as a user, it's obvious the points should connect, however, in computing terms it's handling x numbers to the yth decimal. setting a TOLERANCE simply tells acad to take it easy and put 1 and 1 together.
    04-11-2012 01:05 PM in reply to: FFlix
    PEDITACCEPT is set to 1.  Next time I'll try to change the tolerance to see if that works.
    I did definitely check to see if they were indeed converted to PLINES.  They all were except that the arcs were listed as ARCs (not polylines).  Do the arcs have to list as PLINES in order to do a join?
    Distinguished Mentor
    thepworth
    04-11-2012 02:10 PM in reply to: kimmyz
    also - it used to be a problem if you had polylines going ---> <----- (opposite directions at the join).  Try using the new "reverse" command and joining.
    I usually chicken out & use "mapclean" through Map3D / C3D that resolves this issue - probably doesn't help you tho :smileysad:
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
