AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Calligraph y Revcloud thickness
- Highlight
- Email to a Friend
I can't find a setting that controls the "start" & "end" thicknesses of a Revcloud.
I notice that if I take a calligraphy style revcloud and go to Properties, I can change it to a constant thickness.
But if I change the "Start" & "end" thicknesses, it applies only to the 1st segement.
What I need is to be able to edit the "start" & "end" widths.
Right now it is way to big to use for small revclouds.
What am I missing?
Read Ya Later -KLYPH
Now, just so you'll know I'm inventive when required, I made a polyline where I want the revcloud.
I scaled to twice the size. I revclouded it and reduced it to half the size. Worked just fine.
BUT, I should still be able to adjust the default settings.
Re: Calligraph y Revcloud thickness
- Highlight
- Email to a Friend
Start and end thicknesses are not directly controllable by the user, but _are_ affected by the arc length you are using. to get thinner widths on the calligraphy style, change the minimum and maximum ARC lengths to a shorter value. Since you scaled up and down by a factor of two, typing A after you enter the revcloud command, and halving the arc length defaults should get you similar results., Note that MAX cannot be greater that 3X MIN.
- Highlight
- Email to a Friend
Thanks for the explanation.
It cleared things up.
It sure makes a difference.
And it sure makes a difference whether one puts the cloud in Model vs Paper space.
Again, thanks -KLYPH
