• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Cache all layout tabs at the same time
    937 Views, 7 Replies
    07-25-2011 11:05 AM
    In the options I have "Cache model tab and all layouts" selected. My computer has 12 GB of memory so it does this well. However the first time I switch to a tab it takes a while. Is there anyway to automatically cache all of them at once even before I switch to them? That way I can just get them all cached and work on something else while waiting a long time instead of waiting over and over for short periods of time.
    Please use plain text.
    *Pro
    M_Hensley
    Re: Cache all layout tabs at the same time
    07-25-2011 12:08 PM in reply to: jbear0000
    Instead of caching layouts try setting it to regen when switching layouts. Since most regens are pretty fast these days this will usually give you the fastest way to switch between layouts. (Also it won't use up all your memory by storing all those layout displays.)
    07-25-2011 12:23 PM in reply to: M_Hensley
    That is the opposite of what I want, I have tons of memory and I want to take advatage of it. By setting it to regen every time it is slow, but once a layout is cached then it swicthes really fast. I just want to cach all of them in one shot.
    Distinguished Mentor
    Moshe-A
    07-25-2011 02:35 PM in reply to: jbear0000
    JBear,
    That how AutoCAD handles it's display list
    when you set "Cache model tab and all layouts" (it's the default) it means:-
    when you first open your dwg (in model) the Model tab goes to Cache, when you switch to a Layout tab, that layout appended to Cache and so on. the second time you switch a layout tab it will be from Cache.
    Cheers
    Moshe
    07-26-2011 05:18 AM in reply to: Moshe-A
    Moshe, I know that this is how it works, that isn't what I am asking about. I am asking if anyone knows a command or of a lisp that will force autocad to load them all. Even if it takes a few minutes. I would rather get the waiting done all in one shot instead of waiting 15 times. While it is caching them I could get coffee, work on something else etc. Then when it is done caching I can come back to autocad and it will switch layout tabs quickly.
    pendean
    07-26-2011 06:16 AM in reply to: jbear0000
    Moshe-A
    07-26-2011 01:09 PM in reply to: jbear0000
    attached is a lisp file (made special for you) cache_all_layouts.lsp
    load it manually for each dwg with alot of layouts
    in order to automaticlly run it each time you open a dwg put it in
    application load startup suite. not that openning will be much delayed.
    cheers
    moshe
    07-26-2011 01:22 PM in reply to: Moshe-A
    Moshe, thanks, that is just what I needed, it works great.
