• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    *Expert Elite*
    Patchy
    Re: CAD shuts down at startup
    12-16-2011 03:58 AM in reply to: bart.ribbers
    That seems to be the source of the problem, without 3.5 it will crash.
    (I went thru the same with 2006 and 2008) reformat and reinstall would fix the problem.
    my Win7 64 bit has both installed.
    Please use plain text.
    bart.ribbers
    12-16-2011 04:38 AM in reply to: alfred.neswadba
    Well I deinstalled Framework 4 yesterday, but when I tried to install Framework 3.5 it did nothing... I tried the basic setup and the extended one, and the extended one just unpacked something (which I can't find on the spot it unpacked it) and then did also nothing. So I installed Framework 4 again so I know for sure everything else works.
    I'll try to install 3.5 again while I have 4 installed.
    And I believe I don't even have C:\ProgramData\. But i'm at school right now so I will check when i'm back home.
    Distinguished Contributor
    12-16-2011 08:51 AM in reply to: Patchy
    C:\ProgramData is a hidden folder you may need to change your folder view setting to be able to see it.
    bart.ribbers
    12-16-2011 08:56 AM in reply to: Dazzman
    Thanks i've found it. So I deleted the CascadeInfo.cas but nothing has changed.
    And i'm still not able to install Framework 3.5 somehow... I run the setup, it asks for permissions, and then dissapears without doing anything. The full package and just the setup do the same thing.
    *Expert Elite*
    Patchy
    12-16-2011 09:51 AM in reply to: Patchy
    Find the file called
    acad.exe.config should be in the same folder as acad.exe
    open it with notepad, what does it say in the line
        <supportedRuntime version=" ?????????????????????"/>
    bart.ribbers
    12-16-2011 12:59 PM in reply to: Patchy
    It says "<supportedRuntime version="v4.0"/>"
    *Expert Elite*
    Patchy
    12-16-2011 01:24 PM in reply to: Patchy
    Got to install that 3.5 in there.
    1.  Clean up your TEMP folder by go to:     Start,  Run,  type in:        %temp%
    2.  If there are any anti-virus or antispyware applications running, turned them off
    3.  Right click on the 3.5 SP1.exe and run it as Administrator.
    Write back and let me know how it went.
    bart.ribbers
    12-18-2011 10:56 AM in reply to: Patchy
    After searching for a while, I found out my computer has Framework 1, 2, 3.5, and 4 installed, it just shows only 4 in "Programs and Features".
    I cleaned the TEMP folder, turned my anti-virus off (even deinstalled it), but still no change.
    I'm going to make a clean install of my computer, it sometimes helps, and maybe it also fixes some other things.
    I'll tell you if it helped when the clean install is done.
    *Expert Elite*
    Patchy
    12-18-2011 10:59 AM in reply to: bart.ribbers
    change v4 in acad.exe.config to 3.5###### as it shows in the Add or Remove Program , shut down and restart PC
    before doing anything else
    bart.ribbers
    12-18-2011 11:04 AM in reply to: Patchy
    I'm not able to, it says "Please check whether if this file is opened in another program".
    I've checked in progresses but no AutoDesk program is running.
