• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Re: Bold text inside viewport and slim text inside paper space?
    02-14-2013 05:41 AM in reply to: vladimir.michl
    ELEV was = to 0
    Tryed tu put Z + 100, it's the same on final result. Put back at 0, (has stated on the LIST), still the same.
    Visual style was also into 2Dwireframe, tried the others then put back to 2D but it's inefective.
    Please use plain text.
    Valued Mentor
    TrevN
    02-18-2013 02:30 AM in reply to: Peac3
    It's a bug with no fix!
    You'll have to retype your text.
    Valued Contributor
    02-25-2013 05:55 AM in reply to: Peac3
    Ok then.. this issue should be adressed to the AutoCAD team to repair it. Is it possible to do this?
    *Expert Elite*
    JGerth
    02-25-2013 06:14 AM in reply to: Peac3
    At the very top of the page, on the rightside, is a "Contact Us" link.  Once you're on that page, look for a 'Products' link below the Feedback heading.  Whikle it's far from obvious that that's the place, there is a form to submit issues./ comments.  I don't know if anything there ever gets read or acted upon, but it's what's available.
    Alternatively, if you are working with a reseller, start with them by reporting the oroblem, and making it their problem.
    Member
    02-25-2013 09:20 PM in reply to: Peac3
    One thing I've had to do (you can decide if its worth it) is to explode the mtext to regular text. Sometimes this is enough to remove the boldness, if not, then do the dview twist and/or the elevation to +/- 1 then back to 0.
    let me know how it goes.
