AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Bold text inside viewport and slim text inside paper space?
- Highlight
- Email to a Friend
I have this strange situation.. i use the Arial font inside my cad drawings and when i print my paperspace layout, the text inside the viewport is a little bit more "bold" then the text i put directly on paper space.
Maybe it's a trick to know what text is placed where, but i want all this to be uniform, same thickness. Is there a system variable to correct that issue?
See the image below: It's a 400 DPI scan from an impression i did.
Up to COUPE C1 is the text inside the viewport, under COUPE C1is the paperspace text. Both are the same height... but difference tickness.
Re: Bold text inside viewport and slim text inside paper space?
- Highlight
- Email to a Friend
See also, there is a difference when i look at it directly from Autocad, here is a screen shot. Text inside the view port has some kind of anti-alias problem while the text inside paperspace is fine.
Inside viewport i have a 1:8 scale, text at 16 mm / Outside text is a 2 mm. Exact same height.
If i do a DIST, for the text in PS i get 1.9mm on the letter "T" but inside the Mtext props window it's really 2 mm. Inside the VP the letter "T" is 2 mm (measured in PS)
I just don't understand this situation.. i don't use the "B" bold option on none of the 2 above texts.
- Highlight
- Email to a Friend
There have been various posts regarding similar situations to this and one solution I've seen is to use the "Flatten" command.
Hope this helps.
- Highlight
- Email to a Friend
Hemm flatten is doing no improvments, i try it on PS and VP. Nothing changes.
- Highlight
- Email to a Friend
Check and see if all the text is at the same elevation............
The "flatten" command may not have worked on the text objects
- Highlight
- Email to a Friend
Elevation looks ok for the VP txt, here is the list:
MTEXT Layer: "0"
Space: Model space
Handle = 55e974
Style = "Standard"
Annotative: No
Width: 0.0000
Normal: X= 0.0000 Y= 0.0000 Z= 1.0000
Rotation: 0
Text height: 16.0000
Line spacing: Multiple (1.000000x = 26.6667)
Attachment: MiddleCenter
Flow direction: LtoR
Contents: \pxql;Ruban à masquer 51mm et ruban "tuck tape" \Pvoir images
ci-bas: Lisse au plafond et plancher.
The Z location is 0.
This is for the PS text:
MTEXT Layer: "0"
Space: Paper space
Layout: A2
Color: 1 (red) Linetype: "Continuous"
Handle = 55c5b0
Style = "Standard"
Annotative: No
Width: 79.1185
Rotation: 0
Text height: 2.0000
Line spacing: Multiple (1.000000x = 3.3333)
Attachment: TopLeft
Flow direction: ByStyle
Contents: \pxqc;Ruban rouge "tuck tape" sur\Pruban à masquer vert
- Highlight
- Email to a Friend
use the PLAN command inside the viewpot to ensure that you are in actualality looking straight down,
- Highlight
- Email to a Friend
PLAN + W isn't changing anything. Must be something else.
I tried in 2008, it's the exact same situation. It looks like an option to tell the operator which text is where in case one works in paperspace instead of modelspace.
- Highlight
- Email to a Friend
A couple of things to try, type ELEV, and verify that it's at 0
Next, select the offending text, and change it's Z value in properties to something else, 100 or something. Then, after that, reselct the offending text, and change the Z value back to 0. It's possible that even though the properties dialog _says_ zero inititally, there's a miniscule variation from 0 that hidden by the drawing units precision, or simply a rounding error.
- Highlight
- Email to a Friend
