• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Justin2012
    Bocks
    531 Views, 12 Replies
    04-13-2012 01:45 PM
    Can some referesh my memory about how to use block editor to create, delete,and edit blocks? What I do is copy and paste as block to create a block. Is that a good approach?
    Please assist.
    Thank!
    Please use plain text.
    *Expert Elite*
    Re: Bocks
    04-14-2012 12:09 AM in reply to: Justin2012
    to create a block I just draw the geometry in modelspace (besides my model), then start the command _BLOCK, show this geometry and make a check at "Open in Blockeditor" to continue working on it.
    To modify an existing blockdefinition I look for an inserted block in my drawing, select it, right click ==> Blockeditor
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Justin2012
    Re: Bocks
    04-16-2012 06:01 AM in reply to: alfred.neswadba
    I seem to be a little confuse sir. Do you have a screen shot that I can see, please.? It will be very helpful for my undertsanding.
    Thanks again for your time.
    *Expert Elite*
    Re: Bocks
    04-16-2012 06:33 AM in reply to: Justin2012
    that would be a lot of screenshots ... or better a video. But will a video with the German version of AutoCAD help you?
    The better option would be to scan the help-file for that, there are a lot of screenshots + descritive text, a lot more than I want to write down here.
    For command _BLOCK >>>look here<<<
    For BEDIT (block editor) look >>>here<<<
    - alfred -
    Alfred NESWADBA
    *Expert Elite*
    Re: Bocks
    04-16-2012 09:14 AM in reply to: alfred.neswadba
    You might check some of the free classes here http://au.autodesk.com
    Justin2012
    Re: Blocks
    10-19-2012 09:13 AM in reply to: JDMather
    I have a block with some attribute values and terminals in it. I saved a the block but when I insert it the attribute values and terminals dissapear. Is there a way I can save it correctly to avoid this fmo happening?
    Please..thx.
    *Expert Elite*
    Re: Blocks
    10-19-2012 04:40 PM in reply to: Justin2012
    Attach the file here.
    Justin2012
    Re: Blocks
    10-22-2012 10:30 AM in reply to: JDMather
    How do you save a block with attribute values for future use?
    Justin2012
    Re: Blocks
    12-19-2012 06:37 AM in reply to: JDMather
    I have a two block (same block name) in two different locations for different purpose. I want to distinct the names .How can I change the name of one block without changing the other?When I use the REN command it changes both block.
    Also, I have a block with some default values added but the default values is not showing on my drawing.
    Please let me know. Thanks.
    *Expert Elite*
    Re: Blocks
    12-19-2012 06:59 AM in reply to: Justin2012
    Command: _bedit
    open your block for editing
    Command: _BSAVEAS
    saves your block with a different name, inserts the new one to replace the existing, and erase the old one...
    Hope that helps,
    Henrique
