• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Block Swap Command Error
    255 Views, 5 Replies
    03-27-2012 06:39 PM
    I am running Autocad 2012 and I tried to use the block swap command under the Express Tools. After selecting the block that I want to replace, I get an error stating that the block name contains an invalid character. The name contains invalid characters. The name is: DomeCamera_WallMount, but in the command bar it says object name:*U302. The * is what Autocad doesn't like.
    Any thoughts?
    S
    Please use plain text.
    Valued Contributor
    Re: Block Swap Command Error
    03-27-2012 08:10 PM in reply to: RABCOM
    Sounds like you may have an embedded block within your block (nested block) or you may have used a copy and paste option to insert your block. That's not recommended. Can you use the block editor and go into the block to see if there are other blocks there you may need to remove?
    *Expert Elite*
    heinsite
    03-27-2012 10:29 PM in reply to: PorterCAD
    *U302 indicates that the block is an unnamed, anonymous block.  If you run the PURGE command you'll most likely be able to remove it.  Do that and try your swap command again.
    Dave.
    Dave Hein, P.E.
    Active Contributor
    CSEnginuities
    03-28-2012 04:05 PM in reply to: RABCOM
    I agree with the other user that said this sounds like an embedded block issue.  When all else fails with the blockreplace command, I just insert the new block into the one to replace then explode all instances of the old one.  Voila.
    Clara
    "A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
    *Expert Elite*
    03-29-2012 05:12 PM in reply to: RABCOM
    Is it a dynamic block?
    *Expert Elite*
    heinsite
    03-29-2012 06:12 PM in reply to: ToanDN
    And did a PURGE of all the unused blocks in the drawing make any difference?
    Dave
    Dave Hein, P.E.
