• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Blipmode in AutoCAD 2012
    436 Views, 2 Replies
    07-23-2012 04:38 AM
    Hi, after using an old Lisp program that is protected & I do not access its source code, there is some temporary plus signs, that disappears with “REDRAW” ,“REGEN”, “ZOOM” or “PAN”.
    prior to AutoCAD 2012 with changing the “BLIPMODE” System Variable to “OFF” this problem had been fixed, but for now this command is obsolete. These marker Blips are annoying. Please let me know if there is any solution. Thank You
    Best Regards,
    Soopida Tabib
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Blipmode in AutoCAD 2012
    07-24-2012 11:26 AM in reply to: stabib
    Obsolete but not yet dead, if you use REDEFINE command then BLIPMODE it will be back for you to select 0 or 1.
    Member
    03-25-2013 08:07 AM in reply to: Patchy
    Thanks!
    Windows 7 Professional SP1
    intel CORE i5 vPro i5-3320M 2.60 GHz, 4.00 GB RAM
    Civil 3D 2013
