AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Autosave, AGAIN!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When oh when are Autodesk gonna fix the auotsave bug? This is a major bug that one day is gonna cost me a lot of time and effort!
Everytime I do a large ammount of drawings thru the publish command, autosave is turned off and doesn't come back, it's bloody annoying and should be fixed. Ahhhhhhggggggggggggggg
Re: Autosave, AGAIN!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Forget autosave - turn it off. It is your job to save.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thankyou for that really useful piece of advise!
Now go away, unless you can answer the question.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1) I have agree with JD. Just press Ctrl+S every so often and you'll never need autosave.
2) I have not run across this "bug", but then again, I don't check to see what SAVETIME is set to, so I probably wouldn't notice. As a workaround, you could redefine a command that you use a lot, like ERASE, LINE, or MOVE so that it also sets SAVETIME.
Example:
(defun C:M ()
(princ "\nShortcut for MOVE")
(setvar "savetime" 15)
(command "._Move")
-or- if you want to handle it in a more direct manner, you could use a reactor to 'watch' this variable and set it back whenever it changes. Some example code can be found here: http://cadpanacea.com/node/53
Lastly, have you reported this "bug" to Autodesk?
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Add this to your ACADDOC.LSP
(defun C:ALERTME ()
(vl-load-com)
(setq VTFRXN (vlr-editor-reactor nil '((:VLR-sysVarChanged . VTF))))
(defun VTF (CALL CALLBACK / vtf:nst)
(if (and
(= (strcase (car CALLBACK)) (setq str "SAVETIME"))
(eq (getvar str) 0)
(progn
(princ (strcat "\nWarning: The " (getvar "CMDNAMES") " command has changed your Autosave settings to 0."))
(if (setq vtf:nst (getint "\nEnter new value for SAVETIME <10>: "))
(progn
(setq vtf:st vtf:nst)
(setvar "SAVETIME" vtf:st)
(progn
(setvar "SAVETIME" 10)
(setq vtf:st 10)
(setq vtf:st (getvar "SAVETIME"))
(if (= (getvar "SAVETIME") 0)
(progn
(setq vtf:st (getint "\nSAVETIME is currently set to 0 minutes\nEnter new value for SAVETIME: "))
(c:alertme)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thankyou.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I make QSAVEs as I draw but only when I'm happy with the drawing, I don't blindly Save as a crash recovery tool. We have Autosave for that. And since it saves to a temporary file rather than overwriting your orignal it gives you options if you need to recover a file - and, oh my god, does Autocad know how to corrupt a file...
I've experienced Autosave switching off too, so I simply added a line to my acaddoc.lsp file to ensure it is always on at the start of a session at least.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
TrevN wrote:
Thankyou.
So did you or Autodesk remove the reply to JD?
R.K. McSwain
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Interesting how things work here. Interesting indeed.
When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm glad you mentioned the publish issue. That IS what does it... We've been trying to figure this out for ages.
I agree, save when you are ready to save... not just arbitrarily as with a redefined 'move' command, although, I do tend to type QS pretty frequently. Either way, it's nice to have those Autosave files when you need them.
I'm using the Alertme.lsp now. I stuck it in the LISP portion of our Enterprise menu that's on the network. Works well. It's a bit annoying when it intercepts the publish command, but it's livable. Just hit return and its all good.
http://autocad-lkh.blogspot.com
