• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Mentor
    TrevN
    Autosave, AGAIN!
    3709 Views, 41 Replies
    06-15-2010 01:55 AM
    When oh when are Autodesk gonna fix the auotsave bug? This is a major bug that one day is gonna cost me a lot of time and effort!
    Everytime I do a large ammount of drawings thru the publish command, autosave is turned off and doesn't come back, it's bloody annoying and should be fixed. Ahhhhhhggggggggggggggg
    Please use plain text.
    Re: Autosave, AGAIN!
    06-15-2010 04:40 AM in reply to: TrevN
    Forget autosave - turn it off.  It is your job to save.
    Valued Mentor
    TrevN
    06-15-2010 04:46 AM in reply to: JDMather
    Thankyou for that really useful piece of advise!
    Now go away, unless you can answer the question.
    rkmcswain
    06-15-2010 05:11 AM in reply to: TrevN
    1) I have agree with JD. Just press Ctrl+S every so often and you'll never need autosave.
    2) I have not run across this "bug", but then again, I don't check to see what SAVETIME is set to, so I probably wouldn't notice. As a workaround, you could redefine a command that you use a lot, like ERASE, LINE, or MOVE so that it also sets SAVETIME.
    Example:
    (defun C:M ()
      (princ "\nShortcut for MOVE")
      (setvar "savetime" 15)
      (command "._Move")
    -or- if you want to handle it in a more direct manner, you could use a reactor to 'watch' this variable and set it back whenever it changes. Some example code can be found here: http://cadpanacea.com/node/53
    Lastly, have you reported this "bug" to Autodesk?
    06-15-2010 08:03 AM in reply to: TrevN
    Add this to your ACADDOC.LSP
    (defun C:ALERTME ()
    (vl-load-com)
    (setq VTFRXN (vlr-editor-reactor nil '((:VLR-sysVarChanged . VTF))))
    (defun VTF (CALL CALLBACK / vtf:nst)
    (if (and
    (= (strcase (car CALLBACK)) (setq str "SAVETIME"))
    (eq (getvar str) 0)
    (progn
    (princ (strcat "\nWarning: The " (getvar "CMDNAMES") " command has changed your Autosave settings to 0."))
    (if (setq vtf:nst (getint "\nEnter new value for SAVETIME <10>: "))
    (progn
    (setq vtf:st vtf:nst)
    (setvar "SAVETIME" vtf:st)
    (progn
    (setvar "SAVETIME" 10)
    (setq vtf:st 10)
    (setq vtf:st (getvar "SAVETIME"))
    (if (= (getvar "SAVETIME") 0)
    (progn
    (setq vtf:st (getint "\nSAVETIME is currently set to 0 minutes\nEnter new value for SAVETIME: "))
    (c:alertme)
    Valued Mentor
    TrevN
    06-15-2010 08:31 AM in reply to: RStillwell
    Thankyou.
    Valued Contributor
    06-18-2010 05:42 AM in reply to: rkmcswain
    I make QSAVEs as I draw but only when I'm happy with the drawing, I don't blindly Save as a crash recovery tool. We have Autosave for that. And since it saves to a temporary file rather than overwriting your orignal it gives you options if you need to recover a file - and, oh my god, does Autocad know how to corrupt a file...
    I've experienced Autosave switching off too, so I simply added a line to my acaddoc.lsp file to ensure it is always on at the start of a session at least.
    rkmcswain
    06-18-2010 08:31 AM in reply to: TrevN
    TrevN wrote:
    Thankyou.
    So did you or Autodesk remove the reply to JD?
    Valued Mentor
    stevenelliott3894
    06-18-2010 08:40 AM in reply to: rkmcswain
    Interesting how things work here. Interesting indeed.
    Steven Elliott
    When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
    hardin
    09-08-2010 10:05 AM in reply to: TrevN
    I'm glad you mentioned the publish issue. That IS what does it... We've been trying to figure this out for ages.
    I agree, save when you are ready to save... not just arbitrarily as with a redefined 'move' command, although, I do tend to type QS pretty frequently. Either way, it's nice to have those Autosave files when you need them.
    I'm using the Alertme.lsp now. I stuck it in the LISP portion of our Enterprise menu that's on the network. Works well. It's a bit annoying when it intercepts the publish command, but it's livable. Just hit return and its all good.
    Learn, Practice, Get Better
    http://autocad-lkh.blogspot.com
