• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Autolisp Routines not staying active
    154 Views, 3 Replies
    09-06-2011 09:33 AM
    We have been upgrading our company computers to Inventor 2010 and with that comes autocad. Some of our users are not ready to change over to Inventor and are still using the autocad. The problem is we can not figure out why the lisp routines will not stay active from file to file or when you close down the program and restart the program. We have never had this problem before. Any ideas?
    I currently have to do the following steps every time I open a file:
    Tools
    Load Application
    Select the Files
    And click Load
    I have to do this every time I open a file.
    This is getting really old.
    Any help is greatly appreciated!!!!
    Mike
    Please use plain text.
    Patchy
    Re: Autolisp Routines not staying active
    09-06-2011 09:43 AM in reply to: rcmike
    Appload, add the lisp to startup suite.
    Betreff: Autolisp Routines not staying active
    09-06-2011 09:52 AM in reply to: rcmike
    Yes there are ideas ... so much ... but there is not so much info given. :smileywink:
    What LISP-files are these? Self written or from a developer?
    How are the functions from the LISPs startet? Via menu-buttons or per command-typing?
    What message do you get when you start such a function?
    Very interesting is your info "lisp routines will not stay active" ... does that mean you can start functions of the lisp and one minute later (without closing the drawing or AutoCAD) the functions gives error-messages?
    additional some words for feeding GOOGLE:
    - ACAD.LSP ..... within this file startup-definition are placed, for example what LISPs should be loaded with AutoCAD
    - ACADDOC.LSP  .... here is defined, what LISPs should be loaded with every DWG-open
    - MNL-files .... parallel to menu-files placed, also for loading functions or LISPs
    - _APPLOAD ... command to define tools to be automatically loaded
    HTH, - alfred -
    Alfred NESWADBA
    Valued Contributor
    09-06-2011 10:40 AM in reply to: Patchy
    Thanks Patchy! That was the solution!!!!
