• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Autodesk Exchange add-in issue
    427 Views, 6 Replies
    09-09-2011 01:07 PM
    I recently downloaded 2 of the new apps.  When using the standard autocad profile they showup in the plug-ins ribbon tab with out a problem.   When using our custom profile that we have the only way i can get them on the ribbin is in 2 separate addins tabs and the plugin tab doesn't even show up even though I have it set to showup in the workspace.
    Does any have any ideas on how to get these added in correctly?
    Dylan
    Please use plain text.
    Product Support
    Re: Autodesk Exchange add-in issue
    09-13-2011 06:25 AM in reply to: dcorkill
    Hi Dylan,
    As a suggestion, in the download page of the add-in you will find the customer support email address in case you need assistance.
    You could give it a try and contact the developer of the add-in to see if this is a known issue or if they can help you.
    If this is happening with add-ins developed by different companies then let us know what you have changed in your custom profile.
    Cheers,
    Luciane
    Luciane Conceicao
    Product Support Specialist
    pendean
    09-13-2011 06:32 AM in reply to: dcorkill
    Your custom profile is missing the pathing and load instructions: there is no way for any add on to guess at where your cistom profiles are and preload them. Express Tools is a prime example.
    It might be quickest to reload those apps (especially since you use the same login) for every custom profile you have, while you wait.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    09-13-2011 06:48 AM in reply to: pendean
    Hi Dean,
    I installed the add-ons in the out of the box default profile which would then make them Partial Cui's for Acad.cuix and it added them into the plug-ins tab.   I then took our corporate Cuix file which has Acad.cuix loaded as a partial and added the the plug-ins tab to our ribbon workspace.  This tab wouldn't even showup in autocad when I reloaded the workspace.   Although now having typed all this out I think I see what you mean.  I can't use a a partially loaded cuix from a partially loaded cuix.  SO I would have to partial load the add-in cuix files into my Corporate cuix for it to work.
    Thanks Dean.
    Dylan
    Product Support
    09-13-2011 06:52 AM in reply to: dcorkill
    Hi Dylan,
    If Dean's suggestion helps you, please mark it as an accepted solution.
    Cheers,
    Luciane
    04-03-2012 11:49 PM in reply to: dcorkill
    I recently installed the AutoCAD Architecture 2013.
    Have installed all the FREE Apps without any issues. They all installed within the Plug-ins TAB.
    However, I still have AutoCAD Architecture 2012 installed and all the Apps installed there also but each one has it's own Add-ins TAB. (Most of these Apps had been previously installed from the Autodesk Labs Plug-in of the month and I wonder if I am now loading them twice.)
    Have attempted the CUI and changed all to MERGE TAB etc...
    Have unloaded the individual cuix, have removed the path in OPTIONS but all keep coming back.
    Also, when I close AutoCAD Architecture 2012 I receive now 2 error beeps. (Still working on that one.)
    Closing AutoCAD Architecture 2013 has no issues.
    In my opinion, the Apps should give you an option in which version of AutoCAD... you wish to install to.
    My preference would be to have the Apps installed with the 2013 version.
    My 2012 version was working perfectly before the installation of the Apps.
    Product Support
    06-13-2012 07:13 AM in reply to: Lineabove
    I agree with you and suggest you send your wish to our developers via this page:
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    Cheers,
    Luciane
