• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Re: Autocad gives the wrong area for a polyline
    07-17-2012 02:38 PM in reply to: TerryDotson
    Wait a min! Didn't you say
    "The AREA command can return an invalid number, while the underlying API (Polyline Object .Area Property) returns the correct value."
    I'm getting the wrong answer both ways in that example, unless I'm misunderstanding you?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    Valued Mentor
    TerryDotson
    07-17-2012 04:41 PM in reply to: troma
    Unless you are using some form of programming language to obtain the Area property supplied by the API, you are not seeing it (the correct value).  For example this small LISP routine will dump the properties of an object, including the area.
    07-18-2012 05:50 AM in reply to: TerryDotson
    I tried to use that lisp, I get:
    Command: DUMP
    Select Object: ; error: bad argument type: lentityp nil
    Any ideas?
    07-18-2012 09:31 AM in reply to: troma
    Try this (slight fix)
    07-18-2012 09:39 AM in reply to: dbroad
    Thanks for the fix.
    But have a look Terry, I'm still getting the wrong area:
    New Member
    Re: Autocad gives the wrong area for a polyline can be corrected
    02-07-2013 01:40 AM in reply to: troma
    What I found is that, copy the polyline amd move towards 0,0. List it, check with area command. I hope u may satisfy up to maximum extent.
