AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Autocad gives the wrong area for a polyline
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Wait a min! Didn't you say
"The AREA command can return an invalid number, while the underlying API (Polyline Object .Area Property) returns the correct value."
I'm getting the wrong answer both ways in that example, unless I'm misunderstanding you?
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Unless you are using some form of programming language to obtain the Area property supplied by the API, you are not seeing it (the correct value). For example this small LISP routine will dump the properties of an object, including the area.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried to use that lisp, I get:
Command: DUMP
Select Object: ; error: bad argument type: lentityp nil
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try this (slight fix)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the fix.
But have a look Terry, I'm still getting the wrong area:
Re: Autocad gives the wrong area for a polyline can be corrected
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What I found is that, copy the polyline amd move towards 0,0. List it, check with area command. I hope u may satisfy up to maximum extent.
