• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    autodesk_inventor_user
    Autocad file into CNC - spline problem
    474 Views, 2 Replies
    08-19-2011 03:35 PM
    I saved Inventor file as .dwg in order to make CNC. I need to rout out a wavy reveal in a panel.
    The line on my .dwg file is a spline with thousands of vertexes, using it as a path for the machine wont work, it will take forever to run it since it stops with every vertex.
    What would be the best approach to eliminate the problem?
    Convert the line to what?
    Please use plain text.
    *Expert Elite*
    Re: Autocad file into CNC - spline problem
    08-19-2011 05:49 PM in reply to: autodesk_inventor_user
    If you read thru a lot of these forums, there are always problems with spline usage.  I don't use splines and I highly recommend that splines be avoided at all costs.
    Active Contributor
    GOLEN
    08-22-2011 12:06 PM in reply to: autodesk_inventor_user
    I too use autocad for cnc production and have run into this problem. In express tools there is a tool called flatten. This will take a spline and turn it into arcs or lines. The number of which can be controlled but too many will bloat your program, too few may not give you the result you want.
    ______________________________________________________________
    AutoCAD 2012
    Dell Precision T7400, Intel Xeon @3.4GHz
    Win XP 32bit 4GB RAM
    Nvidia Quadro FX 3700
    Cyborg R.A.T. 7 mouse
