• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Autocad 2012 can't start After installation successfuly complate
    391 Views, 4 Replies
    06-12-2012 02:06 PM
    All I need is why after successful installation of Autocad 2012, the file program after initialization loads can't start normally either I have no error massages.  The Autocad 2012 program open then close less than a second. please guide me with all the steps in order to follow. I do appreciate your concern about this unusual situation.
    Please use plain text.
    *Expert Elite*
    Re: Autocad 2012 can't start After installation successfuly complate
    06-12-2012 02:17 PM in reply to: malimousa
    so you have not yet activated AutoCAD?
    Try the following steps:
    • create a new Windows-user on your system having full admin-rights (at least full for your local pc)
    • login with that user account to your Windows
    • start AutoCAD, if it's Win7 then start it with right-mouse-click and "start as administrator"
    ...and then tell us, what you see :smileywink:
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    New Member
    06-12-2012 07:05 PM in reply to: malimousa
    Hi Mr. Alfred,
    Thank you to respond to my request, I follow your step.  It give me the same result.
    I want to inform you that when I install Autocad 2012 package the Autodesk Design Review 2012 and Inventor Fusion 2012 working perfectly but Autocad 2012 can't start.??????????????????????
    thank you for consideration. Please reply.
    Best Regards,
    M. Ali Mousa
    *Expert Elite*
    06-12-2012 11:23 PM in reply to: malimousa
    then look to the installation log-file, imho a clean uninstall, then update your Windows including servicepacks + Frameworks + install manually the DirectX-drivers from the AutoCAD-DVD.
    After that make sure you have admin-rights, you have disabled all protecting-software (antivirus, defender, ...) and start the setup again.
    Good luck, - alfred -
    Alfred NESWADBA
    New Member
    10-08-2012 05:37 AM in reply to: malimousa
    after log in with different user, the autocad opens, pl advice how to use the old user log in
