AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autocad 2011 crash on startup
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello, i have laptop LG P1 with vista 32bit . I installed autocad 2011 trial with no errors or something.
But when i try to open it,it trys to open for a few seconds and then it crashes with no errors.
Re: Autocad 2011 crash on startup
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
i installed autocad correctly with no errors . The problem is when i try to run autocad
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
i dint find anything helpful there
- Highlight
- Email to a Friend
Hello Michalis11,
Here is a wild guess the system may be trying to open in hardware acceleration and your system may not support it.
1. Try right clicking on the short cut and choosing properties
2. Under target at the end of the short cut link type what is in quotes “ /nohardware”
Then ok out and try to launch.
Hope this helps,
Randall Young
Autodesk Lead Engineer
Autodesk, Inc.
- Highlight
- Email to a Friend
thanks for the reply, i cant check it right now but im sure thats not the problem.
because i found this error in:
ACD2011ELLAdlm
4404 2010/06/27 11:23:56 Reason=Fatal error
4404 2010/06/27 11:23:56 ComputerName=LGP1
4404 2010/06/27 11:23:56 OS=6.0.6002.Service Pack 2
4404 2010/06/27 11:23:56 File=AdlmFlxActTS.cpp,Line=609
4404 2010/06/27 11:23:56 AdlmActError=8 [An item is not found]
4404 2010/06/27 11:23:56 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cp
4404 2010/06/27 11:23:56 AdlmActError=18 [Argument to a function is bad]
3376 2010/06/27 11:23:56 Reason=Fatal error
3376 2010/06/27 11:23:56 ComputerName=LGP1
3376 2010/06/27 11:23:56 OS=6.0.6002.Service Pack 2
3376 2010/06/27 11:23:56 File=AdlmIntSATSLicense.cpp,Line=364
3376 2010/06/27 11:23:56 VendorID=2 [ADLMACT]
3376 2010/06/27 11:23:56 VendorError=18 [Argument to a function is bad]
4164 2010/06/27 11:24:23 Reason=Fatal error
4164 2010/06/27 11:24:23 ComputerName=LGP1
4164 2010/06/27 11:24:23 OS=6.0.6002.Service Pack 2
4164 2010/06/27 11:24:23 File=AdlmFlxActTS.cpp,Line=609
4164 2010/06/27 11:24:23 AdlmActError=8 [An item is not found]
4164 2010/06/27 11:24:23 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cp
4164 2010/06/27 11:24:23 AdlmActError=18 [Argument to a function is bad]
1488 2010/06/27 11:24:23 Reason=Fatal error
1488 2010/06/27 11:24:23 ComputerName=LGP1
1488 2010/06/27 11:24:23 OS=6.0.6002.Service Pack 2
1488 2010/06/27 11:24:23 File=AdlmIntSATSLicense.cpp,Line=364
1488 2010/06/27 11:24:23 VendorID=2 [ADLMACT]
1488 2010/06/27 11:24:23 VendorError=18 [Argument to a function is bad]
5796 2010/06/27 11:34:55 Reason=Fatal error
5796 2010/06/27 11:34:55 ComputerName=LGP1
5796 2010/06/27 11:34:55 OS=6.0.6002.Service Pack 2
5796 2010/06/27 11:34:55 File=AdlmFlxActTS.cpp,Line=609
5796 2010/06/27 11:34:55 AdlmActError=8 [An item is not found]
5796 2010/06/27 11:34:55 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cp
5796 2010/06/27 11:34:55 AdlmActError=18 [Argument to a function is bad]
2768 2010/06/27 11:34:56 Reason=Fatal error
2768 2010/06/27 11:34:56 ComputerName=LGP1
2768 2010/06/27 11:34:56 OS=6.0.6002.Service Pack 2
2768 2010/06/27 11:34:56 File=AdlmIntSATSLicense.cpp,Line=364
2768 2010/06/27 11:34:56 VendorID=2 [ADLMACT]
2768 2010/06/27 11:34:56 VendorError=18 [Argument to a function is bad]
i found a solution i think here: http://forums.autodesk.com/t5/Autodesk-Inventor/In
its for inventor 2010 but i think the problem i have is the same .
but i cant find the legacy_autodesk_licensing_service in "HKEY_LOCAL_MACHI
- Highlight
- Email to a Friend
I was wondering if you had found a solution to your problem? I just installed AutoCAD 2011 and my install does the same thing.
Layton
- Highlight
- Email to a Friend
Michalis11,
Can you post your view tune log?
To do this:
1) 3dconfig
2) view tune log
3) save as and post it.
Randall Young
Autodesk, Inc.
- Highlight
- Email to a Friend
1º run services.msc
2º look for flexnetlicensingservice, must be on "automatic" mode
it worked for me. some kind of antispyware soft was the cause.
