AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Autocad 2011...can 't find express tools..... help menu missing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
One more thing; in 2010 every so often when i have acad open and then open internet exporer, it would shut down my autocad!!!!!????
Re: Autocad 2011...can 't find express tools..... help menu missing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If that does not work, they did not get installed. Try again.
OPTIONS command, set Help to be local to your PC, and not on the Internet
(default).
Dean Saadallah
http://LTisACAD.blogspot.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
AutoCAD 2011 online Help http://docs.autodesk.com/ACD/2011/ENU/landing.html
AutoCAD 2011 CHM-Based Help
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id
AutoCAD 2011 Help in PDF format
http://docs.autodesk.com/ACD/2011/ENU/pdfs/PDF%20D
AutoCAD Wiki Help Beta http://wikihelp.autodesk.com/Product_Help/AutoCAD
Dean Saadallah
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am also new to 2011, upgraded from 2007. I did not load autocad on to my system so Im not sure where to go from here to aquire the expresstools. I did type "expresstools" into the command line and the response was "unknown command". Could anyone help point me in the right direction?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Express Tools are installed by the AutoCAD setup program. Insert the AutoCAD disk and the setup program should start automatically allowing you to ADD Express Tools to your install
or
Start > Settings > Control Panel > Add Remove Programs > AutoCADxxxx > Change/Remove > Add/Remove Features > Express Tools (you may still need the AutoCAD disks to install Express Tools)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
THAT'S WHAT I NEEDED!! Thank you very much. The office won't even know how happy they will be.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Even after doing all that, I get the same error message
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try searching these forums (2011) on Help questions. There is an older post from last spring where a link was given to a downloadable Help file in the old CHM format. Good luck! ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the reply - but even worse - NO CHM help files work on my computer! None, not just ACAD, but none at all. Have tried several things, but nothing works.
