• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    Accepted Solution
    AutoCad LT 2011 frozen when starting
    575 Views, 5 Replies
    09-28-2012 10:13 AM
    One of the computers that have AutoCad installed will not load all the way.  It will start to show the welcome screen and the it will freeze.  Looking on the internet they suggest that you go into task manager and kill the process called WSCommCntr, but it is not appearing in the task manager.
    Originally the pc was on XP SP2 and with .Net 3.5.  I updated both to the latest version.  I have reinstalled AutoCad and I am still getting the issue.  All harware checks passed.
    Also the issue sounds just like the one here http://forums.autodesk.com/t5/AutoCAD-2011/AutoCAD-freezing-on-boot-in-student-lab/td-p/3626436 , but I uninstalled the .Net Framework and reinstalled version 3.5 SP1.  That did not work so I uninstalled that and put on 3.5.  This still is not working.
    Any ideas?
    If it helps my Service Request Number: 07672759
    Edit: Also I am not getting an error message
    Edit: Attached a screen shot of the issue
    Please use plain text.
    *Expert Elite*
    pendean
    Re: AutoCad LT 2011 frozen when starting
    09-28-2012 11:18 AM in reply to: AndyMumm
    If all else fails, or any other suggestions offered do not work, explore these Autodesk recommended uninstall/reinstall procedures
    Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
    Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
    Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
    Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
    If needed, test with another user profile as well.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    09-28-2012 11:28 AM in reply to: AndyMumm
    Uninstalled and installed per the instructions and still nothing.
    I am an admin on the domain so there aren't and rights to conflict during the installation.
    *Expert Elite*
    09-28-2012 11:45 AM in reply to: AndyMumm
    two additional options to try:
    • a) disconnect your workstation from network (and so also from internet)
    • b) login with another user-name (another Windows-account)
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Member
    10-01-2012 11:07 AM in reply to: alfred.neswadba
    Off the network still doesn't work.  (I assume you are checking to see if it is freezing trying to pull updates for the home sscreen)
    Different user accounts:
    User (non admin)
    Me (admin)
    Other IT (admin)
    none of the above user acounts work.
    Member
    10-08-2012 12:57 PM in reply to: AndyMumm
    To fix the issue I built a new machine and installed AutoCAD.
    It would've been nice to get this resolved with the old pc.
