• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Product Support
    Re: AutoCAD crashes during start-up
    03-15-2012 10:48 AM in reply to: adammikulcik
    Try resetting AutoCAD LT to defaults. Click Start > All Programs > Autodesk > AutoCAD LT 2012 > Reset Settings To Default.
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Active Member
    03-15-2012 12:17 PM in reply to: bryce.thelin
    I reset the defaults, and I actually had to copy and paste a number of files from the AutoCAD CD onto my C drive.
    I can no longer remove/repair/reinstall the software.  It won't let me do any of those actions.
    When I try to start the program, the error message is: "Customzation File load failed.  File not found: acadlt."  I click OK and the program closes.
    Product Support
    03-15-2012 12:40 PM in reply to: adammikulcik
    It sounds like you need a clean reinstall at this point. It might be best to post a new thread over on the installation forums, but here are the instructions:
    http://usa.autodesk.com/getdoc/id=TS45252
    You might try a third-party uninstall program first, such as the Revo Uninstaller. Here is their download page:
    http://www.revouninstaller.com/revo_uninstaller_free_download.html
    Let us know how it works out.
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    Active Member
    03-20-2012 07:37 AM in reply to: bryce.thelin
    My IT department ended up re-imaging my computer.  After that point, I was able to install AutoCAD and use it without a problem.
    Thanks for all of the help.
    Product Support
    03-20-2012 08:17 AM in reply to: adammikulcik
    Glad to hear that you got things working again!
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    New Member
    08-14-2012 02:53 AM in reply to: adammikulcik
    Try this
    find any acad.lsp on your computer anywhere and delete. Try again to startup autocad.
    New Member
    08-24-2012 09:12 AM in reply to: adammikulcik
    AutoCAD 2012 hangs on startup for me, on an intermittent basis. One of the regular fixes for me is to go to task manager - services, and turn off the print spooler till it starts. Another one is to clear the temp folder. Obviously I'd rather fix the problem for good, but it does the trick for me.
    Cheers
