• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    AutoCAD crashes during start-up
    3657 Views, 16 Replies
    03-06-2012 12:04 PM
    For some reason, AutoCAD (2012LT) now crashed upon start-up.  The program never actually opens.  It seems to be opening, including all of the Loading scripts, but the last message I see is "Preparing working environment...RIbbon" and then it crashes right before it would open.
    I have un-installed and re-installed.  After re-installing, I downloaded the Service Pack and the Ribbon Hot Fix.  Nothing has worked.
    Any ideas???
    Thanks.
    Please use plain text.
    *Expert Elite*
    Re: AutoCAD crashes during start-up
    03-06-2012 01:16 PM in reply to: adammikulcik
    try to right-click the desktop-icon and start AutoCAD with the option "as administrator".
    You also can try to login to your system with another user-account and check if it crashes then also.
    BTW: what pc / memory / operating-system / graphic-card do you have?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Product Support
    03-06-2012 03:39 PM in reply to: adammikulcik
    Loading of the ribbon could be affected by the .NET Framework. Testing another user account is a good idea though. If it works there, then you can reset AutoCAD LT under your own account by clicking Start > All Programs > Autodesk > AutoCAD LT 2012 > Reset Settings To Default.
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    Active Member
    03-06-2012 05:18 PM in reply to: adammikulcik
    The odd thing is that it was working fine for months.  Then, all of the sudden, the program would open, but I recieved an error code and the program would close immediately.  The error code prompted an online solution from AutoDesk, which was to install AutoCAD 2012 LT Service Pack 1.  After installing the Service Pack, I haven't been able to get the program to open.
    Product Support
    03-07-2012 08:40 AM in reply to: adammikulcik
    What operating system do you have and is it 32- or 64-bit?
    It could be that the settings files for AutoCAD LT were damaged. It tries to load, hits the bad data, and then crashes. Try testing a new administrator user account. That will allow AutoCAD LT to load with a clean initial setup.
    If it's an issue with the .NET Framework, you can uninstall and reinstall this. Just go through Add or Remove Programs (Windows XP) or Programs and Features (Windows Vista/7) and uninstall all the "Microsoft .NET Framework 4" and then download and install it again from here:
    http://www.microsoft.com/download/en/details.aspx?id=17718
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    Active Member
    03-09-2012 11:10 AM in reply to: adammikulcik
    32 bit operating system.
    In terms of the .NET Framework, I have both ".NET Framework Client Profile" and ".NET Framework Extended".  Am I supposed to remove both of those and replace with the link you posted?
    Product Support
    03-09-2012 11:30 AM in reply to: adammikulcik
    Yes, uninstall both the Microsoft .NET Framework 4 and then reinstall from that link. It will put both back.
    Is it Windows XP, Vista, or 7 32-bit that you have?
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    Active Member
    03-11-2012 07:57 PM in reply to: adammikulcik
    I tried un-installing both .Net 4 Frameworks, re-starting the computer, and re-installing them, but AutoCAD didn't start, just as described above.
    I have Windows XP.
    Product Support
    03-12-2012 09:09 AM in reply to: adammikulcik
    Try testing a brand new administrator user account on your system. Let us know if AutoCAD will run under that login.
    Bryce Thelin
    Product Support
    Autodesk, Inc.
    Active Member
    03-15-2012 10:19 AM in reply to: adammikulcik
    I've tried a few things, and now the program actually loads.  However, an error pops up that says: "Customization file load failed.  File not found: C:\Documents and Settings\mikulcia\Application Data\AutoCAD LT 2012 - English\R17\enu\support\acadlt
    I click OK and a message in the upper left hand corner says "The Ribbon does not have any tabs or panels currently loaded."  Then the program closes before I can open a file.
    Any thoughts?
    I haven't been able to have another administrator try to log in yet because I work remotely.
