• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    AutoCAD crashes EVERY time that I change the color of something?
    294 Views, 5 Replies
    10-04-2012 09:18 AM
    I have AutoCAD Mechanical (but only use ACAD), and now every time that I try to change the color of something (line, circle, text...) my AutoCAD crashes!  {This is very frustrating}
    Currently the only way of changing colors is through Layers.
    -Norm
    Please use plain text.
    *Expert Elite*
    pendean
    Re: AutoCAD crashes EVERY time that I change the color of something?
    10-08-2012 09:51 AM in reply to: norm77
    did this just start happening? or did something change right before it started?
    win7? turn off it"s aero theme.
    also change the hardware acceleration in autocad and see if that helps.
    Autodesk Supported Graphics Cards List and drivers:
    http://www.autodesk.com/autocad-graphicscard
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Contributor
    10-09-2012 05:22 AM in reply to: pendean
      As far as I'm aware nothing has changed, and I'm not running Win7 (yet - soon to be upgraded).  My Acad has been working fine since I got it back in 2011 - with the exception of when you flip between programs, and then press the negative key ("-") that it opens the drop down menu as if I've hit "Alt" + "-" ("alt" stays active after switching programs).  I've been using Cad since version 13 and this is the first one that I've had an on-going issues with.
    Unfortunately my company isn't planning on upgrading to a newer version for a year or two (due to the size of the company), so I don't know how to get rid of these issues.
    -Norm
    *Expert Elite*
    pendean
    10-09-2012 06:23 AM in reply to: norm77
    Other than Win7, did you try the other two suggestions I posted?
    Active Contributor
    10-09-2012 06:39 AM in reply to: pendean
    I only saw two options - Win7, and the graphics acceleration.  I tried turning on the hardware acceleration, and then changing the color of a polyline - and it crashed, so no difference.  Is there something I should do differently?  as a note - I don't have admin access.
    The graphics card is a ATI Radeon HD 3450 (and the 'Optiplex 780' PC is running XP Pro).  I've had this computer for well over a year.
    -Norm
    *Expert Elite*
    pendean
    10-11-2012 06:13 AM in reply to: norm77
    It might be worth trying a system restore in Windows back to a month when everything worked.
