• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Member
    AutoCAD LT Upgrade
    227 Views, 3 Replies
    06-30-2012 12:30 PM
    I have installed AutoCAD LT 2013 Upgrade and have completed the registration.  Can AutoCAD LT 2010 now be uninstalled without affecting the new version?
    Please use plain text.
    heinsite
    Re: AutoCAD LT Upgrade
    07-01-2012 05:11 AM in reply to: wmp4406
    Yes.  But it's always a good idea to keep an older version around awhile, "just in case".  It might save you in a crunch.  There are still a few bugs floating around in 2013 that might bite you.  That older version could come in handy.
    When you've had some time with 2013 and feel completely comfortable with it you can always recover the space then.
    Dave.
    Dave Hein, P.E.
    Bob_Zurunkle
    07-28-2012 06:53 PM in reply to: wmp4406
    OP as a heads-up, you'll probably encounter the snap scaling bug -- in other words you go to scale from an endpoint or intersection and it tells you the scale is too small, and cancels the command. One workaround is to not have the cursor directly over the endpoint or intersection when you go to click the mouse button. It apparently doesn't like reading the potential scale as zero....
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    *Pro
    nestly
    07-29-2012 05:25 AM in reply to: Bob_Zurunkle
    That is not a new "bug", and it's entirely avoidable by not putting the basepoint for the SCALE back within the APERTURE when AutoCAD is prompting for a scale factor/destination.
