• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Moderator
    AutoCAD Freeze when displaying a Browse Dialog Box
    306 Views, 2 Replies
    09-23-2011 03:21 PM
    Hi there!!
    I have some issues with AutoCAD 2010, Service pack 2 @ 64 bits, Working on Windows 7 SP1 @64 bits...
    1. Open AutoCAD without any trouble
    2. Press OPEN or NEW or any command that shows a File Dialog Box.
    3. AutoCAD freeze. I must close it from Windows Task Administrator.
    Obviously it is NOT the FILEDIA or something like that. Another thing... if I open a file directly from the Windows Explorer, it opens without any trouble. But if I try to insert (by example) a block using INSERT command and select Browse (It must open an File Dialog Box) AutoCAD freeze too.
    Thanks for the support.
    Natán Villarreal
    http://cadworking.blogspot.mx/
    Please use plain text.
    *Expert Elite*
    Betreff: AutoCAD Freeze when displaying a Browse Dialog Box
    09-24-2011 01:31 AM in reply to: natanworking
    try to set FILEDIA to 0, can you then open files by typing the filename into the command-area?
    Well I know, that's not called "solution", but should be tried to isolate the problem.
    And if your admin is near you, he can give you administrator-rights for a few minutes, try it as admin.
    Also you can try to login to your computer with another user-account, does it happen also with this user?
    And if nothing helps I would do an installation-repair.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Moderator
    09-24-2011 10:07 AM in reply to: alfred.neswadba
    Thanks Alfred, but I've tried (and find) a solution by a different way...
    Actually FILEDIA let me open and save by Command Line, but as you comment, it's not a solution.
    I am the administrator, but tried with another user, getting the same results.
    Fortunately I could find an adequate solution without reinstalling the software. I could find that there were conflicts with Norton 360 Ver 5. When I uninstall Norton 360, everything works well. In fact, there is documentation about troubles between Norton 360 and AutoCAD, even there is a hotfix, but it only works for Norton 360 Ver 3.
    Looks like the trouble has been solved. I hope this experience could help someone else.
    Greetings!!
    Natán Villarreal
