• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    Accepted Solution
    AutoCAD Error Aborting on startup
    439 Views, 6 Replies
    12-29-2012 11:41 AM
    This is the error:
    FATAL ERROR: Unhandled Access Violation Writing 0x0006c Exception at b1e5122h
    just starting getting this error. I tried a repair, and did an uninstall, reinstall. Any help would be appreciated.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: AutoCAD Error Aborting on startup
    12-29-2012 12:02 PM in reply to: danr1707
    What triggered the error?
    When did it start happening?
    Can you recreate the error on demand?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    12-29-2012 12:16 PM in reply to: pendean
    It happens when I try to open AutoCAD. Just started happening.
    I downloaded the DWG reader jsut to try that, but I'm getting the same error on that.
    Makes me think it is a Windows issue. I checked my Windows update history, but there is nothing recent.
    *Expert Elite*
    12-29-2012 12:30 PM in reply to: danr1707
    did AutoCAD ever run and the problem appeard later? Then I would look for the updates, which updates (Windows, antivirus-software, firewall) where installed after AutoCAD worked successfully last time.
    What you can also try: login with another Windows user account and see if the issue is the same.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Member
    12-29-2012 12:33 PM in reply to: alfred.neswadba
    Yes, AutoCAD has always worked before. I did try a different user, same results.
    *Expert Elite*
    12-29-2012 12:42 PM in reply to: danr1707
    So try to catch what modification was done on your system, you also might disable network, antivirus, start AutoCAD with the option (right click in the AutoCAD-icon) "run as Administrator".
    You also may try to restore one of the previous system-states (sorry, I don't know the exact word for that in english)
    A mini-chance might be to start a repair-installation. But as a new installation of TrueView show the same problem I'm really unsure if that will help.
    - alfred -
    Alfred NESWADBA
    Member
    12-29-2012 01:54 PM in reply to: alfred.neswadba
    Yup, figured it out. It was a video driver update. I was able to revert to the old and I disabled the NVIDIA auto update.
    Thanks for all of your help
