>> try improve similar existing ones . i e content explorer and design center, mleader and qleader
Do you have more details to this?`Just "approve it" does not give much info. What is your wish, what can be approved for the leader-objects, for content-explorer (of course there I would suggest performance and ressources), also what about designcenter?
>> make autocad able to have several windows of same drawing
That may be a little bit difficult if you have multiple instances opened, what changes will then be saved if you have one drawing opened 3 times in 3 different editor sessions .... and do modifications in all of them.
Anyway you can resize your AutoCAD application window to start on the left side of the left screen and go up to the right side of the right screen ==> and if you open one drawing, create a layout with 10 different viewports (I do that with 3-4 when working with 3D) and place 5 viewports on the right and the others on the left monitor (whereas 10 is just a sample) .... wouldn't that work also for you. In this case the advantage is you can split not only in two sessions for two monitors, you can split as much as you like, .... but there is only one drawingfile in one editor-session opened.
>> fix cui so users can customize without modifying acad menu group and make upgrade easier
There is again "make it easier" without telling what or how it should be made easier. You have by default a custom area included for user-modifications ... just use it.
But anyway, it starts always with ideas, so just continue and go in depth ...!
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
