AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
AutoCAD 2012 on Windows 8 Developer Preview
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i am running Windows 8 developer preview on my machine, as Windows 7 cannot boot with my specific bootloader method. The installation crashes before it can install the app. I have attached the dump files, and I have submitted these almost 5 times previously, and have not gotten any replies. Is there any way you can help me?
Re: AutoCAD 2012 on Windows 8 Developer Preview
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Actually, It's not truly a support issue, I am able to manually install any Autodesk app on it, and run it just fine, with the minor quirks because of something not being installed. I have managed to boil it down to (I think) the .NET 4 framework. Windows 8 has .NET 4.5 installed, so, is there any way to make the installer skip .NET 4?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just so you know Inventor installs just fine and runs great in Windows 8 beta.... It's the **** Windows Net Framework... coding that is not yet compatable there are several work arounds but AutoDesk needs to fix this....
shopdoug
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
AutoCAD 2012 needs .NET 4.0. I'm guessing this is probably built into Windows 8. That's what Microsoft seems to do with each new version of Windows. You can run the acad.msi to install AutoCAD, which bypasses all the prerequisite checks and installs. It's in your install folder inside the \x64\acad folder.
Bryce Thelin
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Works great.... I had to create a fold insde the Autodesk folder as I had installed Inventor prior to installing AutoCAD....
Thanks for you help......
cadgodintraining
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm glad to hear that worked! If you would, please mark my post as "Accept as Solution."
Bryce Thelin
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes.
What I did in the setup ini file is under "[DOTNET4]" and "[DOTNET4LANG]" I added: "IGNORE_FAILURE=YES"
Look under "[DOTNET20]" few lines below, you can copy it.
To me this way seems more "natural".
Worked like a charm, however i did use autocad mechanical so there might be a difference.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you so much! I used your method to make 2013 CAD working on my Windows 8.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank You Man!!! its perfect solution! Saludos desde argentina!!
