AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: AutoCAD 2012 freezes or lags when using the copy command
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
SORRY, Autodesk! After I saved my file and then opened it back up after filering the layer, the laggin was fixed!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a lagging problem when I select Layer Isolation 10sec each time. we are using V2012. Any suggestion?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I also had this problem. It happened to me on two different computers, one had autocad LT 2012 , the other had autocad 2012. I also had a bazillion layer filters, so I deleted them, and the lagging problem persists.
I'd love to find a solution to this.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I also should add that I notice the lagging in any type of copy related command such as array or mirror.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try turning off the Dynamic UCS. (UCSDETECT change to 0, default is 1). It worked for me.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Deleting extra layer fliters solved this problem for me.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have experienced the same issue. When I paste the cross hair freezes and the drawing crashes. That is the problem, now what is the solution.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I find that extremely impossible to believe, ACAD 2011 and 2012 have been prone with MANY issues, I'm running WIN 7 64 bit anything less and you have snail CAD. Does Autodesk actually run their software in real world environment?
Just curious.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It is NOT RAM related. It is poor code related.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi. My self sandeep chauhan, I also faced the same problem in autocad 2012 when I try to copy clip something hatched.
I simply turn off the notification about the associative hatch, which pop up in upper right corner of autocad.
Hope this will work for you all also.
