• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    Accepted Solution
    AutoCAD 2012 License Error [-15.570.0]
    571 Views, 3 Replies
    01-12-2013 12:59 AM
    A valid license could not be obtained by the network license manager
    Error[-15.570.0] Please see Attached file
    I'm a new comer, I'dont know that what happened this problem
    Please help me out.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: AutoCAD 2012 License Error [-15.570.0]
    01-12-2013 05:48 AM in reply to: Aesupport
    Did you ask your network administrator?
    Is this a new problem?
    Is your PC disconnected from the server?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    *Expert Elite*
    TravisNave
    01-16-2013 01:29 PM in reply to: Aesupport
    It's likely an IPv6 issue.  For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    01-16-2013 05:49 PM in reply to: TravisNave
    finish. Thank you so much
