• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    AutoCAD 2012 Crashing on 64 bit Workstations
    1563 Views, 6 Replies
    12-13-2011 08:51 AM
    We are running AutoCAD Architecture 2012 on a Windows 7......64bit workstation and AutoCAD will suddenly crash for no apparent reason. When I look in the event log it makes a reference to the AcDB18.dll   has anyone seen this before....?? Is there a way to correct this problem....??
    Thank you,
    Vince
    Please use plain text.
    Valued Contributor
    Re: AutoCAD 2012 Crashing on 64 bit Workstations
    12-15-2011 08:15 AM in reply to: vferrara
    What can be done to resolve this....?
    l.tucker
    12-15-2011 08:22 AM in reply to: vferrara
    Is there any error message on the screen? Are you all up to date on service packs and hotfixes (http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618)?
    Valued Contributor
    12-15-2011 09:07 AM in reply to: l.tucker
    I believe we had Service Pack 1 installed.....!
    When the crash occurs I get a message stating AutoCAD can not continue.....Exiting AutoCAD....!
    When I look in the event log there is a reference made to the AcDB18.dll....?  which I do not know if is related to the reason AutoCAD crashed in the first place.
    Vince
    Patchy
    12-15-2011 09:27 AM in reply to: vferrara
    .dll sometimes can be corrupted
    If you have another PC with same operating system, check for the size of the file.
    New Member
    03-21-2012 09:15 PM in reply to: vferrara
    The same happened to me with the Autocad Architecture 2012 ,:smileymad:and I´ve made an experiment: Y crated a model using the new tools : walls, windows blablabla and the system was so cramped that I could´t make a line. Then I tried making the same model in the old fashion way (poliline, extrude, height...) and it run perfect... so in conclusion the new tools are unusefull
    New Member
    03-26-2013 01:31 PM in reply to: vferrara
    I am running AutoCAD LT 2012 on Windows 7, 64 bit. Stops working after plot-save-close or plot-close.
    Ran all available Service packs with actual executable files.
    Am running as admiinistrator.
    What's the deal?
