AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: AutoCAD 2011 crashes immediatel y
- Highlight
- Email to a Friend
- Report Inappropriate Content
I tried that and still get the same result with the exact same error code as my previous post.
I have to say, I really appreciate the help, Travis. Thank you.
- Highlight
- Email to a Friend
That's pretty ridiculous at this point. Those are generally all the tricks that get you past that error. Worst case, remove all of those files completely and then reinstall. It should think it is a fresh install at that point.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: AutoCAD 2011 crashes immediatel y
- Highlight
- Email to a Friend
Yes, it is ridiculous. Sorry to pass my frustrations onto you.
I will do my best to remove everything I can and try another fresh install. My biggest challenge is that I don't want to do anything that will jeopardize my 2008 install since it's the only thing I have operable at the moment. I only have a few more hours to play with this anyway and then I'm just going to have to bite the bullet and go back to 2008 and get caught up.
Again, thank you very much for your input. It is greatly appreciated.
- Highlight
- Email to a Friend
Well fortunately Autodesk changed the licensing scheme with the 2010 product, so only your 2010 and 2011 AutoCAD will not work. It should not affect your exising 2008 at all. Autodesk is pretty good about keeping their products separated from each other.
- Highlight
- Email to a Friend
Noticed your posts and I am having very similar problems with Autcad LT2012.
Did you ever discover the fix?
- Highlight
- Email to a Friend
We had a machine that crashed. After reboot all profiles of AutoCAD refused to open. Deleteing the CascadeInfo.cas file worked for us. Thanks alot
- Highlight
- Email to a Friend
hi friend have you problem same as problem is solved as follows
-uninstall autocad 2011
-erase C:\ProgramData\FLEXnet
-erase C:\ProgramData\Autodesk\Adlm
-install autocad 2011
and fix it
- Highlight
- Email to a Friend
Thanks WORKED FOR ME ![]()
