• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Accepted Solution
    Audit Hangs
    166 Views, 2 Replies
    05-09-2011 11:46 AM
    I am working on a file from an outside firm. Several hours into my work, I get and error that the file needs recovery. When I attempted to RECOVER the file it would consistently hang on "Auditing Entities Pass 2". This also occurred when I opened the file and attempted to AUDIT directly. What is going on?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Audit Hangs
    05-09-2011 11:57 AM in reply to: ekennedy
    WBLOCK out all that you want from this file then try to recover the new file and use it instead.
    Otherwise you may be on the path of a fatal dwg file death in the original.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Re: Audit Hangs
    05-09-2011 12:12 PM in reply to: pendean
    Thanx
