• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Associative Hatch - boundaries
    759 Views, 7 Replies
    05-22-2012 07:36 PM
    Is there a way to maintain associative hatches, but change its functionality when selected slightly.
    Ie: When i select a hatch i have placed in a rectangle, it selects the rectangle also. Properties dialog shows 'ALL (2)' selections instead of only the hatch i originally selected. deleting the hatch, therefore deletes the rectangle.
    Correct me if im wrong, but i recall a time when i could have an associative hatch, and if i selected it, it would be only the hatch object selected, therefore could be deleted without removing the boundary. I now need to go to properties, select the hatch, then change its associativity to 'NO' then delete it?!
    So am i wrong, or am i missing something??
    Please use plain text.
    nijhuis
    Re: Associative Hatch - boundaries
    05-23-2012 03:43 AM in reply to: damo3
    you can turn selection cycle on, then select either the boundary or the hatch
    Active Contributor
    05-23-2012 04:40 AM in reply to: damo3
    You can also change the following System Variable:
    PICKSTYLE
    Change it to 1, (it's probably set to 2 or higher)
    Ryan A Wunderlich
    Royal Caribbean Cruises Ltd.
    *Pro
    nestly
    05-23-2012 06:10 AM in reply to: damo3
    HPBOUNDRETAIN
    0 is OFF
    1 will create an object that encloses each hatch.
    05-23-2012 04:29 PM in reply to: damo3
    Sorry All, everything suggested is already set that way! anything else? This is the exact behaviour:
    Create a rectangle
    pick point an associative hatch and finish
    then select the hatch now and the rectangle will automatically select, properties registers 2 objects.
    now delete the hatch and the rectangle disappears.
    BUT if i select the rectangle only, the hatch WONT be selected. if i delete the rectangle, the hatch remains.
    So, is this expected behaviour? I'm sure this wasnt always the usual behaviour for associative hatches, maybe I'm wrong?
    Valued Contributor
    05-24-2012 08:21 AM in reply to: damo3
    That is weird, since the only way I could mae this happen as you describe is to change my pickstyle which was set to 0 to a value of 2 or 3. Once I put it back to 0 it reverted back to one object selected when the hatch was picked. I also tried it with hpboundretain on, which creates a secondary boundary, that I normally do not use. Even that setting did not make any extra objects being selected when the hatch was picked, if pickstyle was less than 2. Normally I toggle it on or off (1 or 0) with ^ shift A when I am editing groups.
    *Pro
    nestly
    05-24-2012 09:19 AM in reply to: Dave_S
    Yeah, after testing, I'd have to say PICKSTYLE 2 behaves as described and PICKSTYLE 1 does not.
    Try this combination (the defaults)
    PICKSTYLE = 1
    HPASSOC  = 1
    HPBOUNDRETAIN = 0
    05-24-2012 03:44 PM in reply to: damo3
    cheers everyone, seems to have done the trick. Although, i think i may have lead you all astray because when i booted up this morning my pickstyle was set to 3. changing it to 1 rectified the problem as was suggested earlier in the thread. I did check this value earlier though so Im not sure where i have gone wrong, but none the less, 3 new variables to brush up on.
    thanks.
